This is a board that I did for guitarist, Mark Holley.
Mark is touring with Mr. Big (Eric Martin) and wanted a board that he could use for the tour as well as is other projects.
Enjoy it Mark!
INTERFACE
Vertex Tri-Buffer (input buffer, two output buffers), Effects Break-Out (to insert effects off of the pedalboard, but in the middle of the signal path between the distortion/overdrive pedals and the modulation pedals), and a Reverb Pass-Through to switch the amp reverb on/off from a footpedal on the pedalboard.
POWER SUPPLY
Voodoo Lab Pedal Power 2+
ORDER OF EFFECTS
Crybaby Classic Wah, MJM Britbender, Lovepedal Tchula, Voodoo Lab Micro Vibe, INTERFACE (input buffer), Menatone Top Boost In A Can, Vertex Plexitone, INTERFACE (effects break-out), Strymon Lex, Empress Tremolo, Empress Vintage Modified Superdelay, /13 Switchazel (A/B + Boost), INTERFACE (dual output buffers for amplifiers A and B)
*Reverb footpedal feeds trough the interface and switches the amp reverb on/off for a Divided by 13 amp that is part of the A/B set-up.
*Boss TU-12 tuner is run out of the Switchazel.
VERTEX - Pedalboard (Mr. Big, Eric Martin Content)
VERTEX EFFECTS SYSTEMS
Custom Pedalboard Design
