The pedalboard thread...
kairos05
Re: The pedalboard thread...
Post by kairos05 »
Hi John ive been searching the voodoo lab site for the "current double cable" but havent find it (i've been looking in http://www.voodoolab.com/cables.htm and nothing...where can i get that cable?
Thank you very much!
This is a newer cable and is not yet up on our site. Please give us a call or write to info@voodoolab.com to order direct or to find a dealer near you that may have it in stock. Good Luck!
kairos05
Post by kairos05 »
JohnClark wrote:This is a newer cable and is not yet up on our site. Please give us a call or write to info@voodoolab.com to order direct or to find a dealer near you that may have it in stock. Good Luck!
Already called, my cable is on its way!
Thank you for your support John!
BurnTheSky
Post by BurnTheSky »
Here's my board !
I had to wire it in a pinch for upcoming gigs and auditions, and figured it looked nice (still messy though, but it's supposed to be a semi-temporary solution, until I get the funds for a small switcher and a GC Pro).
Some VL products in here: a PP2+, which powers everything (including my TimeFactor, with polarity reverse cable, and using outlet 5 with switch engaged), and a 4-button Tremolo (sounds great !).
It's supposed to be used with the wah, compressor, OD, chorus and trem in front of the amp, and CAE boost and TF in the loop.
Quite compact and powerful, it'll serve me well I'm sure !
Ty Gerhardt
Post by Ty Gerhardt »
This doesn't include my "loose" pedals that I use for recording...
Emil_V_Zhak
Post by Emil_V_Zhak »
DSC00381 copy.JPG (93.72 KiB) Viewed 16207 times
monk
Post by monk »
modulo
Post by modulo »
Here's mine for now.....
Marshall JVM 210H 100w
1960a cab with G12T75 and Vintage 30's
Fractal Audio AX8
Guitars:
IBANEZ JEM PMC
IBANEZ JEMjr Desert Yellow
EVH Wolfgang Vintage white
