Which Pedal Power ca I use for a second One?
Hollywoody59
Post by Hollywoody59 »
Hi Folks,
I have a special question and hope some forum readers will have
experience or the same think over?
I use on my board the fantastic PedalPower2 plus!! Amazing good
the mercedes benz under all the other.
Now I want to take a second Pedal Power only for some effects so
I could reduce the power of the PP2 plus with pedals.
My Board has the following equipment:
Vox Wah Joe Satriani - Xotic RC Boost - Fulltone OCD - Mad Prof Distortion-
Wampler Ego Comp - Wampler Tape echo Delay -Voodoo Lab Pedalswitch -
Wampler Pinnacle-
Again following effects - Boss DD20 delay - Maxon Flanger FL9 - Fulltone Plimsoul
-Boss RC 20 XL Looper
So which Pedal Power I can use for a second effectline on the board??
I think I don't need a second PP2 plus, more one of the smaller Voodoos???
Thanks for all helping knowledge!!
Hollywoody
Rez
Re: Which Pedal Power ca I use for a second One?
Post by Rez »
You could use either ISO-5 or Pedal Power Digital.
However, ISO-5 has the 18VDC output which you can use with your Plimsoul.
Note: You can use the AC courtesy outlet to power an additional Pedal Power 2 Plus, ISO-5, Pedal Power Digital or Pedal Power AC. You can connect a power strip to the courtesy outlet for use with multiple pedals/effects and their adapters. The courtesy outlet is NOT designed for use with power amplifiers or other high power equipment.
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
