Hi!
is it possible to power the TC Nova System with the AC Auxiliary of the PP2+??
thanks
Sigi
Pedal Power 2+ & TC Nova System?
Re: Pedal Power 2+ & TC Nova System?
Yes, you can use the Pedal Power 2 Plus AC courtesy outlet as you have described.
You can connect a power strip to the courtesy outlet for use with multiple pedals/effects and their adapters.
It may also be used to power an additional Pedal Power 2 Plus, ISO-5, Pedal Power Digital or Pedal Power AC.
The courtesy outlet is NOT designed for use with power amplifiers or other high power equipment.
Cheers!
Cheers!
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
Ben Resnick
I’m currently trying to power a TC Nova System via the courtesy outlet on a PP2+ using one of these:
Although it powers up, there doesn’t seem to be any output from it. However, when I power up the Nova via a wall wart, it works fine.
Any ideas?
Any ideas?
Not sure how you are using a wall wart to power the Nova system, but I guess that isnt really the point here...TFC365 wrote:I’m currently trying to power a TC Nova System via the courtesy outlet on a PP2+ using one of these:
Any ideas?
The same IEC cord used to power the Pedal Power 2+ will work to power the Nova System. I don't see why it wouldn't work with the cable linked above.
Are both the Pedal Power 2+ and the Nova System mounted to something conductive, like a metal pedalboard?
If you set it up using the Pedal Power 2+ and the linked cable and confirm that it gets no sound, does the sound come back if you pull the main power cord out of the Pedal Power 2+ and plug it directly into the Nova System without changing any other cables?
