Pedal switcher hum
Darran
Pedal switcher hum
Post by Darran »
Hi
I've recently purchased a Moen GEC438 pedal switcher in order to switch between the various distortion pedals on my board.
For power I'm using a Voodoo Labs Pedal Power 2. The problem I'm having is when the loop is engaged I'm experiencing a hum/buzzing caused by any pedal that's near or above the pedal supply. When I remove the Moen from the set-up, I don't have this problem.
Any ideas on how to solve this problem?
Darran
JulianShur
Re: Pedal switcher hum
Post by JulianShur »
How is your board set up? Are you daisy chaining or using different power supplies for the pedals and switcher?
Julian Shur
