Using one output on the Pedal Power 2+ to power two pedals?
lukemarsh
Post by lukemarsh »
I have the PP2+ but all of the ports are filled up and I want to add more pedals to my rig... maybe even just one! Some of the pedals I use draw very little current so I was wondering if it was possible to connect two 9v pedals of low mA draw to one single port on the PP2+? (I'm assuming you'd have to select it to 18v to do both?)
I've got some of the micro Mooer pedals, which I'm assuming draw little mA current... otherwise, I have some pedals that I know draw very little. I really just don't want to cart around a single power supply for one extra pedal!
Cheers
JulianShur
Re: Using one output on the Pedal Power 2+ to power two peda
Post by JulianShur »
So you want a daisy chain cable, Part# PPAV . Leave the output at 9V, and just remember that these two pedals will no longer be isolated.
Hope that helps.
Julian Shur
