Hello friends!
I just purchased two VooDoo Lab PP2+ Power Supplies to power my PT PRO... but I'm unsure of which power setting to use for each pedal. Most of the manufacturers state in their instruction pamphlets that their pedals should only be used with the power supplies that come with their products. Is that the case? Where does that leave me? Lol - My biggest fear is damaging any of my pedals.
Firstly, can these pedals be powered by the PP2+? If so, which PP2+ setting should be used for each pedal? Any help would be greatly appreciated Thanks!
EHX Slammi
EHX Cathedral Stereo Reverb
EHX Pog 2
Boss DD-20
Boss TU-3
MXR M-108 Ten Band Graphic EQ
MXR M-101 Phase 90
MXR M-115 Distortion iii
Emerson EM-Drive Transparent Over Drive
Wampler Paisley Drive
Way Huge Aqua Puss Analog Delay
Powering My Pedal Board
Re: Powering My Pedal Board
All of the switches on the back of the PP2+ units should be set towards normal, and you'll use all black cables, no reds. You'll need to purchase a voltage doubler:JonBJohn wrote: EHX Slammi - normal output
EHX Cathedral Stereo Reverb - output 5 or 6 on PP2+, requires ~200mA
EHX Pog 2 - output 5 or 6 on PP2+, requires ~180mA
Boss DD-20 - output 5 or 6 on PP2+, requires ~200mA
Boss TU-3 - normal output
MXR M-108 Ten Band Graphic EQ - requires 18V, voltage doubler, normal outputs
MXR M-101 Phase 90 - normal output
MXR M-115 Distortion iii - normal output
Emerson EM-Drive Transparent Over Drive - normal output
Wampler Paisley Drive - normal putput
Way Huge Aqua Puss Analog Delay - normal output
http://www.voodoolab.com/shop/index.php?cPath=22_24_32
Top or bottom cable - bottom one is just an extender. Middle red one is unsuitable.
