Powering Eventide H9 plus Line 6 M9
Corygaff
Post by Corygaff »
Guys please help! Needing to get a power supply that can power an Eventide h9 and a line 6 h9 plus 3 9v pedals!
Thank you!
Re: Powering Eventide H9 plus Line 6 M9
The Pedal Power 4x4 should do it!
The latest "trick" to power the Line 6 M9 is to use two of the High Current 12V outputs combined with a Current Doubler Adapter.
The eventide H9 can be powered from one of the High Current 9V outputs, and the three other pedals should be able to each be powered from the 9V 100mA outputs.
Corygaff
Post by Corygaff »
Has this theory been tested? If it works then that would be perfect! Always thought the m9 could only be powered with its own supplied power supply!
Only here that I know of... http://www.voodoolab.com/forum/viewtopic.php?f=5&t=6041 (I know he doesn't specify in that thread, but I did hear from him directly on exactly how he was powering his M9.) ;)
User stilwel is someone I do trust, but I will admit that I have not tested this with an M9 myself. :oops: I "know a guy" that can get me a Digital/4x4/Mondo... I just don't have an M9 to go with it.
Ovation661
Post by Ovation661 »
I have a mondo as well. What cable did u use ro plugin to the doubler cable? Was it the one with the red tip?
Ovation661 wrote:Hi,
The Red ended cable is the one to use with either of these pedals.
stilwel
Post by stilwel »
Thanks John!
Yeah I have been powering my M9 as John described for a few months now. No issues to report. Fwiw...I also did the math before I tried it.
