So, here my needs:
i have to power 3 pedals 10/20 ma each and a whor... hem.. the glab gsc-2. I've asked g-lab techs about power needs, and without using the 9v out it requires 330Ma @ 12v in the worst condition. That means the iso-5 is fitting perfectly to my setup, BUT i am 100% confident it wont be out until april 2010.
Looking at specs i could join the 2 high current outs of PP2, but what exactly means unregolated? does it supply 12v or it will be floating?
What means exactly unregulated?
Re: What means exactly unregulated?
Unregulated means that the output voltage will be dependent on the current demand. As shown in the Pedal Power 2+ manual, on output 5 or 6 switched away from Normal you can expect an output of 14.5V with a 50mA load... while a 200mA load will pull the voltage down to 9V.
I know this will only fuel the fire, but I know a dude on the inside and he completely disagrees with your estimate on the release date of ISO-5. Hint: it's much sooner than you think.
Hmm.. so this mean that my board "might" crash by power fault when limit conditions are reached. Rare to happen, but possible.
I am nailed up to Iso-5. My thougths were based on marketing considerations, but i will be glad to finish and post pictures of my pedalboard sooner
Thanx for advice
Thanx for advice
