I recently increased my board from 8 to 18 powered pedals and upgraded to a Novo 32 pedaltrain.
To help power all the new pedals, I bought a PP3+ to go along with my original PP2+.
I know the PP2+ has a courtesy outlet, which I assume means I can hook them together instead of having to use them side by side. (I did not see a courtesy outlet on the newer supply).
I'm not the most technical/electrical adept person, so I was hoping for some advice or guidance on what was the best way to get the two supplies to work together, and if there are certain pedals that need to go in certain inputs. Much appreciated!
This is what I will be plugging in:
Boss TU-2 55 mA
Dunlop CBM95 Cry Baby Mini 0.9 mA
Mooer Yellow Comp 10 mA
EHX Green Russian Big Muff 2.2 mA
Boss SD-1 10 mA
ProCo Rat (1986 Black Face) ? mA
Boss CE-2 (1985 vintage) 9 mA
EHX Deluxe Electric Mistress 40 mA
Catalinbread Coriolis Effect 70 mA
EXH Small Stone Nano 10 mA
Boss TR-2 25 mA
Death by Audio Micro Dream 28 mA
Boss DD-3 35 mA
EHX Stereo Memory Man w/Hazarai 200 mA
Catalinbread Cloak 60 mA
Matthews Astronomer 65 mA
Walrus Slo 80 mA
TC Ditto X2 100 mA
Combining PP2+ and PP3+ with courtesy outlet
Re: Combining PP2+ and PP3+ with courtesy outlet
It's perfectly fine to power the Pedal Power 3 Plus from the AC courtesy outlet of the Pedal Power 2 Plus.
As for what goes where, here are the details, including, links to additional items which are required (but are not in included with your stock Pedal Power cables):
To power the ProCo Rat (1986 Black Face) use any 9VDC output with 3.5mm Mini Plug cable, part# PPMIN, PPMIN-R
To power the Boss CE-2 (1985 vintage) use any 12V output with one of the all black (standard polarity) cables.
To power the EHX Deluxe Electric Mistress (9V model) use any 9VDC output with one of the all black (standard polarity) cables.
Or,
To power the EHX Deluxe Electric Mistress (24V model) use any two 12V outputs with a Voltage Doubler Cable (reverse polarity, 2.5/2.1mm), part# PPEH24
To power the EHX Stereo Memory Man w/Hazarai use a 9VDC high current capacity (250mA or 500mA) output with one of the all black (standard polarity) cables.
To power the remaining pedals, each:
Boss TU-2 55 mA
Boss SD-1 10 mA
Boss TR-2 25 mA
Boss DD-3 35 mA
Catalinbread Cloak
Matthews Astronomer
Walrus Slo
TC Ditto X2
use any 9V output with one of the all black (standard polarity) cables.
Hope this helps!
Or,
Boss TU-2 55 mA
Boss SD-1 10 mA
Boss TR-2 25 mA
Boss DD-3 35 mA
Catalinbread Cloak
Matthews Astronomer
Walrus Slo
TC Ditto X2
Hope this helps!
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
Ben Resnick
