Which pedal power do I need?
ihave27frets
Post by ihave27frets »
Im running and assortment of pedals of various brands and im not sure of their power requirements, any help would be great :D
maxon od9 pro+
maxon phase tone pt999
suhr shida drive
guyatone flip series tube echo
hbe germania
hbe detox eq
Re: Which pedal power do I need?
The PT999, the Shiba Drive, the Germania and the Detox can each be powered from any output of a Pedal Power 2+ switched to Normal. The Germania will require a Reverse Polarity cable. The Tube Echo should be able to be powered using output 5 or 6 switched away from Normal. Due to its unique voltage doubling circuit, which requires a huge current spike at startup, the OD9 Pro+ will likely need to be powered using an adapter connected to the Courtesy Outlet on the back of the Pedal Power 2+. I hope that helps!
