Empress DElay and Line6 MM4 on output 5& 6??
gillento
Post by gillento »
I am rather new to this and I am trying to figure out if it is possible to use the outputs 5 & 6 of the PP2+ to power both the Empress Superdelay (9-12VDC 300ma, centre pos) and the Line6 MM4 (Line6 claims that it's possible to power it with 12 VDC 500ma)
Will these work together?
ninzanstudio
Re: Empress DElay and Line6 MM4 on output 5& 6??
Post by ninzanstudio »
I believe so, but Mr. Clark should be able to confirm for sure. Both outputs would be switched away from NORMAL.
I would plug them in and see what happens. This setup would be right at the limits for these two outputs so I cannot say for sure what would happen here. There certainly would be no harm caused by trying it out. If for some reason there are problems, you could power one of these two pedals using the supplied adapter connected to the Courtesy Outlet.
