AC Courtesy Outlet???
sonhawk
Post by sonhawk »
Hello,
Can I plug in a 12V 300mA digital pedal into this AC Auxiliary outlet??? Would it draw what it needs? or would it damage my pedal?
DC outlets 5 and 6 are almost suitable but don't quite meet the required 300mA for this specific pedal.
Sean
Trueman
Re: AC Courtesy Outlet???
Post by Trueman »
Plugging into the Courtesey Outlet as you descibed will be fine. It was designed for applications like these.
Connoisseur of good tone.
http://www.guitarpedals.co.nz
John01W
Post by John01W »
How difficult it would be to rotate the courtesy outlet 180 degrees?
Nork
Post by Nork »
It sounds like you're trying to power a ND1 or something the likes of TC Electronics. The AC outlet on the PP2 will do it for sure. Outputs 5&6, with the DIP switched away from normal are also supposed to be able to put out this kind of power. I talked to John @ VL and he said they'd had LOTS of success with it.
Good Luck....
Nick
greenmachine
Post by greenmachine »
Will the AC courtesy outlet power the Digitech Timebender? I think it's 9VAC 1.3 amps.
Trueman
Post by Trueman »
Yes all you are doing is utilising the adaptor that came with the pedal. Should be fine no problems.
