ISO 5 & VL Ground Control Pro
Jeremy
Post by Jeremy »
This was hinted at on the HRI Forum last year when the ISO 5 was still in development (then the high output was 500mA). Can the ISO 5 power the GCPro with the high output 9V @ 300mA?
Thanks! :mrgreen:
Re: ISO 5 & VL Ground Control Pro
The High Current 9V output on the ISO-5 can be used to power a Ground Control Pro.
Jeremy
Post by Jeremy »
Hey John,
To bump this old question, if I use the High Output 9VDC on the ISO 5, do I have to use a reverse polarity cable? Or can I use a standard cable?
For this you would use the Red ended barrel cable so it fits the 2.5mm power jack on the Ground Control Pro. Good Luck!
arizona guitarist
Post by arizona guitarist »
JohnClark wrote:The High Current 9V output on the ISO-5 can be used to power a Ground Control Pro.
...and phantom power a Pedal Switcher? But I would probably be more interested in the PP2+.
The Pedal Switcher does not accept phantom power.
arizona guitarist
JohnClark wrote:The Pedal Switcher does not accept phantom power.
Sorry, the other way around...can it power the Pedal Switcher and still let the Pedal Switcher power the Ground Control?
I'm going to have to say no to this one. The current load would likely be too much for reliable operation. Also, the Pedal Switcher should get 12V when using DC power. Good luck!
