Can I power a Line 6 Helix HX with Voodoo Lab?
Posted: Sat Mar 09, 2019 12:43 pm
by KikoInLA
I'm about to build a new board using the PX-8+ and Dingbat board, but I'm trying to decide on what power supply to use. My biggest concern will be powering a Line 6 Helix HX (Effects only version of Helix). Is there a Voodoo Lab product that can do this? I believe that power supply is 500ma at 9V. At least that's that the only spec I could find. But I'm wondering if it's just using that power supply because it exists and is actually lower (I really hoping it's lower). Any help would be fantastic!
Re: Can I power a Line 6 Helix HX with Voodoo Lab?
Posted: Mon Mar 11, 2019 1:28 pm
by Rez
Either one of these supplies:
Pedal Power 4 x 4
Pedal Power MONDO
could be used but with also a custom cable available from Voodoo Lab (to order email inquiry to
info@voodoolab.com or call 707 545-0600).
To power your HX Effects use two 9VDC high current capacity (400mA) outputs and a custom cable (current doubler with 2.5mm output barrel, standard polarity).
Or, if using
Pedal Power 2 Plus, power it from the AC courtesy outlet with its
adapter/wall-wart.
Cheers!
Posted: Mon Mar 11, 2019 9:08 pm
by KikoInLA
Thanks for the info!!!
Posted: Tue Mar 12, 2019 10:09 am
by Rez
Posted: Tue Jun 04, 2019 4:25 pm
by bmartee913
I'm assuming you could also use the courtesy plug on the Mondo to power the HX as well, right?
Posted: Fri Jun 07, 2019 12:13 pm
by Rez
Absolutely, yes it's fine to power from the AC courtesy outlet with its adapter/wall-wart.
Cheers!
Posted: Thu Aug 08, 2019 8:27 am
by Chris in MD
What about a PP2+ using two of the high current outputs?
Posted: Thu Aug 08, 2019 10:02 am
by Rez
No, as outputs 5 and 6 are 250mA capacity each, combining them as such will not suffice to power the HX (two 400mA outputs are necessary).
However, you can certainly power it from the Pedal Power 2 Plus AC courtesy outlet with its adapter!
