recommendations for Irig Stomp I/O and wammy Ricochet
Posted: Fri Apr 03, 2020 11:31 am
by Markus_B
HI Guys
Im looking for some power suggestions as my previous pedal power does'nt power the Wammy Ricochet pedal plus i have a Irig Multimedia Stomp I/O floorBoard controller which the manual says use the included AC adaptor
Use only the specified AC adaptor you can buy at: www.ikmultimedia.com/irigpsu3a
Use only the specified AC adaptor (iRig PSU 3A) and make sure the line voltage at the installation matches the
input voltage specified on the AC adaptor’s body.
IK Multimedia will not be responsible of any damage caused by usage of any AC adaptor other than the
specified one (iRig PSU 3A).
The usage of AC adaptors other than the specified one (iRig PSU 3A) could compromise the user experience in
terms of:
• Safety risk
• Apple device charging performances
• Noise performances
but the specs shows .
Conversion: 24-bit A/D, 24-bit D/A
Sampling Rate: 44.1 kHz, 48 kHz, 88.2 kHz and 96 kHz
Power: USB bus powered (when used with a computer) or DC IN
Device Connection: USB B-Type and Mini-DIN
https://www.ikmultimedia.com/products/i ... ?p=manuals
The Adaptor says on the bottom:
Input: 100-240V~50/60Hz 0.75A
Output: 5.0V 300mA 15W
Approval NO:TUV020538EA - + (minus-plus)
The Stomp I/O can also power from usb such as a laptop or a AC plug like one used for a phone etc.
Is there a product that can cater for both devices as well as a few more 9V pedals
thanks
markus
Re: recommendations for Irig Stomp I/O and wammy Ricochet
Posted: Mon Apr 06, 2020 2:42 pm
by Rez
The Whammy Ricochet has an actual current draw of 235 mA and can be powered from any of our current production DC power supplies.
To power the Whammy Ricochet use a 9VDC high current capacity (250mA or 400mA) output with one of the all black (standard polarity) cables supplied.
But, the iRig would need to power with its adapter/wall-wart.
Either of supplies could be used: Pedal Power 2 Plus or Pedal Power Mondo
Hope this helps.
Cheers!
