Complete novice seeking advice
Posted: Wed Oct 21, 2020 8:45 pm
by FrannieB
G'day from Australia
I have the Pedal Power 2 Plus powering my board. Excuse my ignorance, but I really have no idea about how best to choose or configure the settings on the power board for my pedals, and would appreciate advice. At the moment I've randomly assigned pedals to the 4 ACA, 2 L6 and 2 SAG outputs and all the switches on the underside of the power pack are set to normal. I'm using the following pedals:
Korg Pitchblack chromatic tuner
Boss AC3 acoustic simulator
Digitech Mosaic 12 string emulator
Behringer OD 300 Overdrive/Distortion
MXR Micro chorus
TC Electronics Thunderstorm flanger
Nux Time Core Delay
TC Electronics Hall of Fame Reverb
Thanks everyone, and I hope someday to have learned enough to be able to help someone else in turn!!!
FrannieB
Re: Complete novice seeking advice
Posted: Tue Nov 10, 2020 9:56 am
by Rez
Most 9V battery type stompboxes require less than 100mA current and can be powered from any of the 9VDC Pedal Power 2 Plus outputs.
This is the case for all your pedals, except... the Mosaic (it requires more than 100mA and thus must power from one of the high current capacity outputs 5 or 6).
To power the Mosaic with Pedal Power 2 Plus use output 5 or 6, its DIP switch set normal with one of the all black (standard polarity) cables supplied.
For all other of your pedals, each: use any 9VDC output with one of the all black (standard polarity) cables supplied.
Cheers!
