hi to everyone,i'm new to the forum and i hope this is the right room where to post this.I'm currently facing a problem.I got my pedaboard and i wanted to add a pedal (MXR M222 TALK BOX)that requires 1A at 18 v but i can't do this with just the 2 plus even with the current/voltage doubler cables.My question is: can i run all my pedals with just the voodoolab 2 plus and run the MXR with it's own external power supply without having noise or hum issues? (everything ,even the amps,are connected to the same outlet in my room)
thanks to everyone who will answer
VooDoolab 2 plus and external power supply
Re: VooDoolab 2 plus and external power supply
It's fine.
Simply power the MXR M222 Talkbox with its power adapter, it will not create any problems.
And, certainly its power adapter could be powered from the Pedal Power 2 Plus AC courtesy outlet (if that is desired).
