Hi I recently purchased a Keeley Compressor Plus and it requires a centre negative plug for the power. I was wondering if a 1Spot reverse polarity adapter would work with the PP2+
Use 1Spot Reverse Polarity Cable with Pedal Power 2 Plus?
Re: Use 1Spot Reverse Polarity Cable with Pedal Power 2 Plus?
No adapter needed.
In the "guitar world"... center negative is standard polarity (center positive is reverse polarity).
To power the Keeley Compressor Plus with Pedal Power 2 Plus, use any 9VDC output with one of the all black (standard polarity) cables supplied.
