Setting for Pedal Power 2 Plus?
leocesario
Post by leocesario »
Hi, all.
I always had the DC Brick as my power supply, but recently got the Pedal Power 2 Plus. One thing I liked about the DC Brick is that it has a pretty straightforward operation. The Voodoo Lab however has all these different types of outputs and I just don't wanna fry everything up but using the wrong connections.
How would you power the following set?
- MXR 134 Stereo Chorus (18v)
- MXR Phase 95 (9v)
- MXR Carbon Copy (9v)
- Keeley Compressor Plus (9v)
Re: Setting for Pedal Power 2 Plus?
Post by Rez »
With all 8 DIP switches in the 9V (normal) setting, all 8 Pedal Power 2 Plus outputs are 9VDC... simple.
To power the MXR 134 Stereo Chorus (18v) use a Voltage Doubler Cable (standard polarity, 2.1mm), part# PPY in any two 9VDC outputs.
To power these:
- MXR Phase 95 (9v)
for each, use any 9VDC output with one of the all black (standard polarity) cables supplied.
