Can you use a parallel Y cable with the Sag outputs?
Posted: Wed Mar 10, 2010 11:10 pm
by The Blue Letter
Is it possible to use the Sag Outputs of a PP2+ and a parallel cable to effectively get the right voltage and mA rating? I am trying to power a 12V pedal at 200mA without having to use the courtesy outlet, and ports 5 and 6 are already being used.
So I was wondering if I sagged the output of ports 7 & 8 each to 6 volts and used it with a parallel Y cable would that work?
Please let me know. Thanks a lot.
Dan
Re: Can you use a parallel Y cable with the Sag outputs?
Posted: Thu Mar 11, 2010 12:40 pm
The SAG outputs will not work for this as the output would still be 9V when using the parallel cable. What is the pedal you are trying to power?
Posted: Thu Mar 11, 2010 10:53 pm
by The Blue Letter
I am trying to figure out a way to power my Guyatone VT-X Tremelo pedal. Like I mentioned previously, I am really trying not to use the courtesy outlet. I hate the wall warts, and port 5 and 6 are already being used. I am not sure if there is a way to combine any of the other output ports to power it, but if there is even a way of modding it internally to get what I need I am confident enough in my soldering skills and such to do the job. Let me know if you have any ideas or any other creative options. Thanks again
Dan
Posted: Fri Mar 12, 2010 11:57 am
Since you are already using outputs 5 and 6 you can instead use a parallel cable from any two of outputs 1-4 with their DIP switches set away from Normal for the VT-X.
Posted: Fri Mar 12, 2010 12:33 pm
by The Blue Letter
I am assuming it would be the PPY model of "Y" cable and not the PPEH24. Right?
Thanks again as always for all your help John. You rule!
Posted: Fri Mar 12, 2010 1:29 pm
It would not be either of those cables. You need a Parallel Y cable, which currently is a custom cable and as such is not shown on the stock cable list at this time. Feel free to give us a call or send an email to
info@voodoolab.com to order the appropriate cable for this.
Posted: Fri Mar 12, 2010 11:14 pm
by The Blue Letter
Ok awesome thanks for the advice. I am looking for a few other things as well so I will be calling Voodoo Lab on Monday to order all of this stuff. Thanks for the info once again.
Dan
