Pedal Power Plus 2 and Keeley Monterey
Guitarguy1964
Post by Guitarguy1964 »
I understand that for pedals over 100ma I need to use outputs 5 or 6 on the pedal power plus 2 but what about the Keeley Monterey which is rated right at 100ma? Is it safe to run the Monterey in outputs 1-4? I am already running 5 and 6 for a Wampler Terraform and a Keeley Cavern v.2.
Thanks for your help!
Re: Pedal Power Plus 2 and Keeley Monterey
Post by Rez »
Yes, it should be fine to power your Keeley Monterey from any of the 9V 100mA outputs.
That said... If you want to be extra certain you could A/B it between a 100mA output and a 250mA output to confirm it's working 100% (ie. as expected).
