Will these plugs work for a Pedal Power 2+ and an ISO 5?
Posted: Tue Jul 20, 2021 6:52 am
I'm hoping to wire custom lengths for power cabling off of the power cable on my Temple pedal boards plug using maybe 14-18ga wire comparable to an extension cord. I came across these plug ends on amazon and was curious if they would work to plug into the Pedal Power 2 + and ISO 5? I need something at an angle for space reasons so if they do it seems like a perfect fit.
IEC Lock+ PA130100RBK Right or Left Angle The World's First Locking Rewireable IEC320-C13 Connectors No More Accidental Unplugging or Disconnections (Left/Right) https://www.amazon.com/dp/B07NP7D3PJ/re ... UTF8&psc=1
Also wanted to make sure I can daisy chain a second pedal power and a ISO 5 off of pedal power courtesy outlet too. Here's my board power supply setup based on how everything is mounted on top:
https://drive.google.com/file/d/1RxLpAm ... p=drivesdk
