Voodoo Labs 2 + with Eventide Black Hole
tonyfalcon
Post by tonyfalcon »
Hi all,
I was wondering if anyone knew how i would power an Eventide Black Hole (9v 200ma) with Voodoo Labs 2 Plus?
I was thinking it could just go into either of the 250ma on 5 or 6? Or could i double two of the 100ma outputs with a PPAP?
The reason I ask is because i was thinking of using 5&6 to power a Eventide Time Facor.
tonyfalcon
Re: Voodoo Labs 2 + with Eventide Black Hole
Post by Rez »
To power the Eventide Black Hole with Pedal Power 2 Plus, use output 5 or 6 with one of the all black (standard polarity) cables supplied.
And, for the TimeFactor using both high current outputs (5 and 6) is not necessary...
To power the TimeFactor with Pedal Power 2 Plus, use a Current Doubler Adapter, part# PPAP in outputs 4 and 5 (or 6 and 7), DIP switch in the 9V (normal) setting and a 2.1mm/2.5mm Reverse Polarity Barrel Cable, part# PPL6, PPL6-R (red end fits the TimeFactor).
Hope this helps!
