X4 input voltage range?
Istvan
Post by Istvan »
Hi, can I power the X4 from a portable power station using 13.5V DC? What is the supported voltage range?
Cheers
Re: X4 input voltage range?
Post by Rez »
No... not likely.
I don't know the exact tolerance, sorry. But, it's pretty tight.
In case it helps, the 12VDC power adapter for Pedal Power X4 is available here: 12VDC power adapter
