I currently have a Mondo and a 4x4 and was curious what the correct cable and input I should be using to power my 24v Q-Tron+?
Also curious what cable and inputs I should use to power my EVH Flanger, which is 18v?
Thanks in advance - just not real curious to find out the wrong way to plug in these pedals with the Mondo or 4x4 and possibly fry my pedals.
Correct cable/outlet needed for QTron+ for Mondo/4x4
Re: Correct cable/outlet needed for QTron+ for Mondo/4x4
To power the Q-Tron+ (24VDC), use a Voltage Doubler Cable (reverse polarity, 2.5/2.1mm), part# PPEH24 in any two 12V outputs. Note, if the 12V output of a 9/12V pair is used... leave the paired 9V output empty.
To power the 18V EVH Flanger, use any two 9V outputs with a Voltage Doubler Cable (standard polarity, 2.1mm), part# PPY. Note, if the 9V output of a 9/12V pair is used... leave the paired 12V output empty.
Hope this helps!
Hope this helps!
Hi Rez-
I want to power a Q-Tron+ (24v) and a MXR 10 band eq using my pedal power 3.
I have the proper doubler cables. PPEH24 for QTRON and PPY for MXR.
Can I power both of those using pedal power 3? If so, how?
Thank in advance,
CC
Thank in advance,
CC
Yes.
For the Q-Tron+, use the two selectable 9/12V outputs each set to 12V with the Voltage Doubler Cable (reverse polarity, 2.5/2.1mm), part# PPEH24.
For the 18V MXR use any two 9V outputs with the Voltage Doubler Cable (standard polarity, 2.1mm), part# PPY.
