Hi, I have had a VL PP3+ for the past several months and a few days ago the VL output splitters have stopped working.
I have 3 of these attached to the 12 outputs = 15 in total.
I've checked the outputs are working fine with a single lead.
But i've found with the splitters, one of the leads works, but the lead with the white marking strip is not working.
So i decided to order some more VL splitter adapters, but I've just tried them and the issue remains.
All my pedals are 9v and rated under 100mA, except the Boss DD200 (225mA) which is not using a splitter.
the 200mA outputs are set to 9v, and do not have splitters in.
Does this mean there is an issue with my PP3+, or is there a limit on the number of splitters I can run?
If so, would I be better to just add an X4 extender?
Output Splitters stopped working on VL PP3+
Re: Output Splitters stopped working on VL PP3+
The trouble that the lead with the white stripe does not work is fairly common but (usually) it is merely a result of how the output splitter is designed (and not a malfunction).
The lead with the white stripe has its ground lifted. The device powered from this lead must get its electrical ground connection via the audio signal path. So, this device will need to be connected to the rest of your pedals before it will power on. This design is intentional as it eliminates the possibility of creating a ground loop (a common source of unwanted hum/buzz when daisy chaining power).
I suspect the Output Splitter Adapter will work properly once both pedals (on the splitter) are also included together (via the instrument cables) as part of the same audio/signal path.
Hope this helps!
Hope this helps!
