Hi I saw on two different Y cables on the net.
VOODOO LAB Y- 18/24 VOLT 5,5 X 2,5MMCABLE Voodoo Lab Y- 18Volt/24Volt Cable, 5.5mm x 2.5mm - Reverse Polarity (straight), Combines two Pedal Power outputs (both in 12V mode) to create 24V. Used to power various Electro-Harmonix effects like the Deluxe Memory Man, Stereo Memory Man, Deluxe Electric Mistress, Micro Synthesizer, Bass..
And
VOODOO LAB Y- 18 VOLT CABLE Voodoo Lab Y- 18 Volt cable Combines two Pedal Power outputs (both in standard 9V mode) to create 18V, Great for powering pedals like the Fulltone OCD, Fulldrive 2, Fat Boost or other pedals, length: app. 50 cm
Can you tell me please which one is for the pitch factor please?
The site I saw this is Thomann.de
I live in europe
Thank you
Mathieu
PP Y cables for eventide pitch factor
Re: PP Y cables for eventide pitch factor
Neither one of those cables is the correct one. For any of the Eventide "Factor" pedals, you will want to use the Parallel Y Cable. This can be ordered direct from us by writing to info@voodoolab.com or by ordering it through any Voodoo Lab dealer.
But I Think Thomann.de is a voodoo lab dealer (the biggest music cyberstore in Europe), this is where i bought my pedal power 2 plus. They also sell commander, switcher, ground control and pedals etc ... But I don't see another Y cable than those two. 2 bad.
Do you know where I can find it in France.
Thank you
Mathieu.
Thank you
Mathieu.
You are only looking at their web site... give them a call and they will be able to order this cable for you. This cable is relatively new and isn't even on our own web site yet.
I called Voodoo Lab a couple weeks ago and ordered this exact cable. I spoke with Harmony who was very helpful and knew what I was talking about as soon as I said TimeFactor. It is a Y cable and doubles the current on outlets 5 and 6 with the switches set away from "Normal". I understand it will work on either Pedal Power models (2 and 2+). I expect it any day now. You can specify the length as well as straight or right angle connectors as well.
