Pedal Power 3+ Temperature
IronStomach
Post by IronStomach »
Hello, I'm using a Pedal Power 3+ mounted under a Fender medium pedalboard and with the summer heat I've noticed it gets really hot after about 30 minutes of use, almost uncomfortable to touch. I'm powering 12 pedals and a lot of them are digital/high current draw, so I know it's working hard, but should I be concerned about sustaining those temperatures?
Re: Pedal Power 3+ Temperature
Post by Rez »
Generally, use as such should be fine and even in the summer heat... The supply is quite robust.
That said, if any malfunction develops, certainly contact us (info@voodoolab.com) for additional assistance.
Thank you!
