Pedal Power 2 plus w/ 3 high current requirement pedals
SpainK27
Post by SpainK27 »
I just purchased the Boss RC-500 to start looping. I already have a Strymon Blue Sky and a Boss DD-20 Giga Delay which both require the 5 or 6 inputs on the voodoo labs pedal power 2 plus. In order to power the RC-500 I need to order a current doubler and connect it to either the 4/5 or 6/7 inputs. Is there any way to power all 3 of these pedals with the voodoo labs pedal power 2 plus? Could I order another current doubler and power one of the other pedals with 2 of the lower current inputs?
Rez
Re: Pedal Power 2 plus w/ 3 high current requirement pedals
Post by Rez »
Yes.
To power the Boss RC-550, use a Current Doubler Adapter, part# PPAP in outputs 4 and 5 (or 6 and 7), DIP switches set normal (9VDC) with one of the all black (standard polarity) cables.
And, to power the Blue Sky use a Current Doubler Adapter, part# PPAP in any two outputs, DIP switches set normal (9VDC) with one of the all black (standard polarity) cables.
Cheers!
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
