Just wanted to see if this is possible. I know you can power one h9 w/ a current double in spots 5 & 6. My rig is essentially going to be 2 h9s plus another 3 or 4 pedals potentially.
Sean
Pedal Power 2+ and 2 Eventide H9s
Re: Pedal Power 2+ and 2 Eventide H9s
Yes, possible.
To power the 1st H9 use a Current Doubler Adapter, part# PPAP in outputs 4 and 5, DIP switches set normal (9VDC) with a 2.1mm/2.5mm Reverse Polarity Barrel Cable, part# PPL6, PPL6-R
And similarly, to power the 2nd H9 use a Current Doubler Adapter, part# PPAP in outputs 6 and 7, DIP switches set normal (9VDC) with a 2.1mm/2.5mm Reverse Polarity Barrel Cable, part# PPL6, PPL6-R
Hope this helps!
Hope this helps!
