Mounting question
Posted: Wed Jun 09, 2010 4:20 pm
by brothertony
I have a Gator Pedal Tote (the small one) and there is certainly room to mount my Pedal Power under it, but it seems the mounting screws it comes with are only designed to work with the gator power supply (as far as I can tell). I was wondering if anyone had any alternative methods I could use in mounting the Pedal Power to my board. Thanks in advance.
Re: Mounting question
Posted: Thu Jul 14, 2011 1:33 pm
by goran
20 inches of 3M Dual Lock (SJ3560) can work. It will not attach on unpainted wood. Maybe you need to put some more black paint under the board? Let it dry for 24 hours.
Make sure the PP is clean. Use isopropyl alcohol (rubbing alcohol) on both the PP and the board. Cut the Dual Lock in four pieces (5"), lock them together, peal of the tape and put them on the PP. Peal of the other tape side and press the PP under the board.
Good luck,
G
