Please Help! - Strymon and Digitech
Posted: Thu Nov 11, 2010 11:06 am
by JSMidd
I have been using two PP2+ untis to power my PT-Pro, and I'm having some trouble with a few pedals...
1. Strymon Blue Sky.
I've tried this in both the 5 and 6 slot of the PP2, tried flipping the normal switch both ways, and it will not power up... or it powers up weakly with a clicking sound.
2. Strymon El Capistan.... same issue as Blue Sky
3. Digitech Jamman Delay. It's a 9V unit, but none of the supplied cables I have will power it.
Thanks to anyone who can respond with help.
Sam
Re: Please Help! - Strymon and Digitech
Posted: Thu Nov 11, 2010 11:20 am
by Jon Wilder
JSMidd wrote:I have been using two PP2+ untis to power my PT-Pro, and I'm having some trouble with a few pedals...
Sam
The Digitech Jamman Delay requires AC power and something less than 600mA, thus cannot be powered by the Pedal Power 2+. However, the Digitech Jamman Delay can be powered from a Pedal Power AC.
The Strymon products call for a 500mA source. If powering them from outputs 5 or 6 without a current doubler adapter is giving the result of "weak power", this typically means that it draws something more than 250mA but less than 500mA. A current doubler adapter will be needed to pair up outputs 5 & 6 for a 500mA source. This means that you can only power 1 Strymon unit from each Pedal Power 2+.
You can order the current doubler adapter from us via contacting us at (707) 545-0600 ext 110 between the hours of 9AM and 5PM PST Monday through Friday. we accept Visa, Master Card, American Express and Discover cards.
Posted: Thu Nov 11, 2010 11:22 am
by JSMidd
Thank you, Jon.
I will get those ordered.
Posted: Fri Nov 12, 2010 12:22 pm
by Jon Wilder
Just got this email directly from Terry at Strymon -
"All of our DSP based products consume right around 200mA so they should operate on your PP2+ outputs 5 or 6 with the DIP switches in the normal position."
This means that either output 5 OR 6 with the corresponding DIP switch in the "Normal" position should be able to power your Strymon units just fine without the need for the current doubler adapter.
Posted: Mon Nov 15, 2010 1:28 pm
by ninzanstudio
Jon Wilder wrote:Just got this email directly from Terry at Strymon -
Hi Jon - this is great info! However, I have seen some comments from El Capistan users (over at TheGearPage.net forum) who have experienced some under powering symptoms using only one port (5 or 6) on the PP2+. Their solution was to use the current double adapter (as you first suggested) or the supplied AC adapter plugged into the courtesy outlet.
