Dunlop Dimebag Wah
BOSS Noise Supressor
BOSS DD-7 Digital delay
BBE Sonic Stomp
Modded Boss Monte Allums Compressor Sustainer
BOSS Super Shifter PS-5
Morpheus Droptune pedal
Keeley Ibanez Tube Screamer
MXR Fullbore Metal
Will Pedal Power 2 power my rig ??
Re: Will Pedal Power 2 power my rig ??
The Pedal Power 2+ will power everything with the exception of the Morpheus Drop Tune. I can't say for sure whether or not the PP2+ will power it as they do not publish their power specs. If nothing else you can power it from the courtesy outlet with its manufacturer supplied power pack.
You will have just enough outputs to power everything on your list. If you need to add a pedal later on you'll need to purchase one of our split Y adapters to split one output into two outputs.
Jon Wilder
Voodoo Lab
Tech Support
Voodoo Lab
Tech Support
thanks alot Jon
