PP2 with Vox and Moog
JSMidd
Post by JSMidd »
I have PP2+, four of them power my main rig. I am trying to power a Vox Big Bad Wah and a Moog MoogerFooger 12-Stage Phaser, and neither are powering up. Which cable should I be using?
Re: PP2 with Vox and Moog
The Vox Big Bad Wah can be powered using the standard barrel cable included with the Pedal Power 2+ from any output with the corresponding DIP switch set to Normal.
The Moogerfooger MF-103 12-Stage Phaser can be powered using the optional reverse polarity cable with the white end from output 5 or 6 on a Pedal Power 2+ with the corresponding DIP switch set to Normal.
