Can Commander switch the channels on my Triple Rectifier?
Can Commander switch the channels on my Triple Rectifier? I see a lot about a/b ing 2 amps, but can it switch just from dirty to clean and turn on 2 pedals?
Re: Can Commander switch the channels on my Triple Rectifier
It is the Control Switcher that will actually control the amplifier channels and functions, while the Pedal Switcher will handle the effects bypass switching.
The Commander is a controller for our Pedal Switcher and Control Switcher. Using a Commander to control these devices will give you ten presets that you can program to set the amp channel you want and select the effects simultaneously. An unlimited number of Pedal Switchers and Control Switchers can be controlled by the Commander.
