Will the iso 5 power the following pedals? Or can I do it from my pedal power 2 (not+)
TC Nova drive
Keeley compressor
Keeley fuzz
Fulltone fat boost
Way huge aqua puss
Dunlop uni-vibe
And if I were to add another 9v pedal could I daisy chain together from one of the outputs??
Iso5 nova uni-vibe and more
Re: Iso5 nova uni-vibe and more
An ISO-5 would power all these with only a single optional Split Output Y cable needed to power two of the standard 9V pedals. You can use the 18V output for the Uni-Vibe and the High Current 12V Output for the Nova Drive. The rest of the pedals can be powered from the remaining 9V Outputs.
Thanks Ill order one
Cheers
Cheers
How about running the Uni-vibe from a pedal power 2? Which cable would i need, its 18v. Do i run it from 5 and 6 or can I use the sag 6 and 7 outs?
A Pedal Power 2 wouldn't be able to power both the Uni-Vibe and the Nova Drive from the front panel outputs.
