Peddle power
Peddle power
Can I use the pp2 to pwr my digitech harwire (9v) peddles RV7 and SC2 ?
Re: Peddle power
No worries; rest assured that your Digitech HardWire RV7 and SC2 will rock mightily when powered by a PP2.
Scary Terry
Voodoo Lab Customer Support
Scary Terry
Re: Peddle power
Nice comment!Terry Buddingh wrote:No worries; rest assured that your Digitech HardWire RV7 and SC2 will rock mightily when powered by a PP2.
Scary Terry
Connoisseur of good tone.
http://www.guitarpedals.co.nz
Re: Peddle power
Hi. I'm new here - first post. I just bought a PP2+ and I have a Hardwire RV-7. So I'm resurrecting this old thread.
On another forum I read that someone had contacted Digitech customer support and was told that the startup draw of that pedal is 300mA, meaning that over time without 300mA, the pedal will become damaged. I've been using a large capacity wall-wart for mine, so that hasn't been an issue. But I'd like to confirm if the PP2+ can be used for the RV-7, in light of that customer support comment, given that that the max any port on the PP2+ has is 250mA?
Re: Pedal Power
Your RV-7 will be just fine to be powered from a Pedal Power 2+, ... confirmed!
The outputs on a Pedal Power 2+ (or any model Pedal Power) are not hard limited. This means that they can actually provide more than the rated current for a limited amount of time.
I hope this helps!
I hope this helps!
