PPII (non-plus) and Line 6 Digital Modelers
Posted: Sat Jul 11, 2009 10:48 am
by iand1821
Is it possible to power 2 Line 6 Digital Modelers (MM4 and DM4) with the Pedal Power II NON plus version? If it is, I assume I should use outlets 5 and 6 right?
Thanks in advance!
Ian
Re: PPII (non-plus) and Line 6 Digital Modelers
Posted: Mon Jul 13, 2009 10:21 am
by Mark V
The short answer is, look at the slots 5 & 6 on the PPII and you will see "L6" above each slot.
Use the red barrel cables included, set the switch away from "Normal" and you are good to go.
Posted: Mon Jul 13, 2009 3:10 pm
by iand1821
great thanks!
