I've got a Tone Bender Mk2 clone that I want to run with my Pedal Power Plus 2 box.
Embarrassingly, I can't really make sense of the manual as pertains to this action.
Do I need to flip the dip switch on the corresponding power out?
Do I need to order a special cable or can I do this with the cords that came with the PP+2?
Positive Ground with PP+2
Re: Positive Ground with PP+2
Since this pedal requires only 9V you would leave the DIP switch for the output used in the Normal position. For reverse polarity, a.k.a. Center Positive, you would need to get the PPREV cable. You can get this cable from virtually any Voodoo Lab dealer or through our online cable store at http://www.voodoolab.com/shop/index.php?cPath=22 or by writing to info@voodoolab.com or by giving us a call directly... but those are your "only" choices
John, thanks for the prompt reply and the clear answer. I'm ordering some of these now.
Also, thanks for all your help last year getting my VL system up and running. It's worked flawlessly since you walked me through everything. I really appreciate it.
\m/
