good idea to run 4x4 in the courtesy outlet of a PP2+?
i just placed my preorder for a 4x4 through sweetwater. i'll be using to alongside my PP2+. my plan is to "daisy chain" the two power supplies, so that the 4x4 runs into the courtesy outlet of the PP2+, which then plugs into the wall. is this a bad idea? surge strip space sometimes gets at a premium, so it'd be nice to power my entire board with essentially one cable.
Re: good idea to run 4x4 in the courtesy outlet of a PP2+?
Any Pedal Power unit can be powered from the Courtesy Outlet of any other Pedal Power unit, without exception... forever
great to hear. should powering it this way create any additional noise? i just placed my order with sweetwater. can't wait to try it out!
No noise will result from doing this.
