RJM Mastermind and Pedal Power
davisband
Post by davisband »
I have a Pedal Power 2 (not the +) and was wondering if I could power the RJM Mastermind MIDI controller (manual stats 9VDC 200ma) from ouput 5 or 6. Do I need to flip the dip switch from normal? On the original pedal power does the dip switch make it unregulated?
JulianShur
Re: RJM Mastermind and Pedal Power
Post by JulianShur »
Output 5 or 6, DIP set to NORMAL, that should work.
Hope that helps.
Julian Shur
