Pedal Power Mondo Question
Posted: Sun Mar 16, 2014 4:03 pm
by dimar5150
I'm looking to get a one stop pedal power for my board which has 11 pedals on it.
They are mostly Boss but if I plug a pedal into a power slot that that can be used for digital pedals with higher outputs with a lower output pedal such as a Boss DS1, will it work? Can I damage the pedal power or the pedal itself?
Re: Pedal Power Mondo Question
Posted: Sun Mar 16, 2014 5:03 pm
by sagaci
No it won't damage the pedal. As long as the output mA is higher than what the pedal uses, it's fine. A "high-current" 400mA output won't damage a 5mA distortion pedal.
Posted: Mon Mar 17, 2014 5:08 pm
by dimar5150
And I can power up to what looks like 14 pedals, if they are all 9v?
Posted: Tue Mar 18, 2014 8:08 am
by sagaci
As long as you don't exceed the rated output, it should be fine. Make sure all the pedals on the one output are the same polarity, ie. centre-negative.
Posted: Tue Mar 18, 2014 3:15 pm
dimar5150 wrote:And I can power up to what looks like 14 pedals, if they are all 9v?
Without daisy-chaining, that'd be 12 pedals at 9V. Two of the output sections on the far left have a 9V Jack and a 12V Jack that share the 400mA capacity.
Other than that, sagaci has you on the right track!
p.s. Thanks to sagaci for helping out around here!
