PP2 and Ibanez ad80
Posted: Fri Sep 04, 2009 5:24 pm
by acdc518
hi, I was wondering which cable i need to power an old ibanez ad80 off a PP2+?
thanks
Re: PP2 and Ibanez ad80
Posted: Tue Sep 08, 2009 11:54 am
That all depends on your AD80... some seem to use a barrel connector and some use the 1/8" mini plug, there are also 9v and 18v versions of this pedal. The Pedal Power 2+ can power any of these variations.
Posted: Tue Sep 08, 2009 12:50 pm
by acdc518
mine is 18volt and i noticed there are 2 different kinds of 18volt adapters. any idea which one i need?
Posted: Tue Sep 08, 2009 2:54 pm
I believe you would need a custom cable that combines two outputs to yield the 18v and has a 1/8" mini plug on the pedal end. If you could tell us what connector is on your pedal, that would help a lot.
Posted: Tue Sep 08, 2009 3:53 pm
by acdc518
its an 1/8'' miniplug. i have an adapter that will change a boss style plug to a 1/8'' plug
Posted: Wed Sep 09, 2009 12:57 pm
acdc518 wrote:its an 1/8'' miniplug. i have an adapter that will change a boss style plug to a 1/8'' plug
In that case you can use the 18v Y cable (PPY) or you can have us make a custom cable with the mini plug already on it... the choice is yours! Power to the Pedals!
Posted: Wed Sep 09, 2009 1:16 pm
by acdc518
thanks. i will order a ppy.
