Most of the threads on this forum seem to focus on the PP 2+ and I don't see a whole lot on the PP Digital. I actually have both on my new board. As such, does anyone have thoughts on how to best power:
Pigtronix Exolution 2 Deluxe
EHX Electric Mistress (new version)
Strymon Flint
Thanks in advance for your help.
Pedal Power Digital Question
Re: Pedal Power Digital Question
Well the cheapest and easiest way to power those three pedals is with an ISO-5.
Echolution 2 needs 18V
Flint needs 9V high current (400mA output)
Stereo Electric Mistress needs a current doubler into the two 9V's to get 200mA.
Otherwise you could use a PP Digital but you'd need a voltage doubler for the Echolution 2.
Or you could put the Flint and Mistress on output 5 and 6 on the PP2+ and again use a voltage doubler on two of the remaining outputs to get 18v for the Echolution 2.
Thanks for the help but I already have a PP2+ and a PP Digital so I need to figure out how to power them with these two devices.
The Echolution 2 and the Electronic Mistress (original or New) can each be powered using a Voltage Doubler Adapter connected to any two outputs on the Pedal Power 2+ with the DIP switches set to Normal, or any two 9V outputs on the Pedal Power Digital.
The Flint can be powered from output 5 or 6 on a Pedal Power 2+ with the corresponding DIP switch set to Normal, or from any 9V output on the Pedal Power Digital.
