Pedal Power and X2 XDS-Plus
Posted: Mon Sep 07, 2009 11:36 am
Can the PP2+ power a X2 XDS-Plus wireless receiver, using one of the L6 outputs with the DIP-switch set to ON?
According to the specs the XDS-Plus needs 9V / 300 mA. A pro rackbuilder states that using output 5 or 6 on the PP2+ with the DIP-switch set to ON (resulting in higher voltage and higher amperage) works without any problem. I'd be happy with that but I need confirmation.
If so, does this also work with the PP2 (not the Plus)?
