Attempting to use Pedal Power 2 Plus w/Vocalist Live 2 ??
DRJM
Post by DRJM »
Hello,
I am trying to use Pedal Power 2 Plus with the DigiTech Vocalist Live 2. I have not been successful in making the pedal power 2 the power source. Do you have any suggestions on which outputs I should use? Currently I am using output 6 with the dip switch away from NORMAL position.
If this helps anyone the power supply indicates that its Output: 9V ~ 1.3A
I am trying to avoid making a small AC Extension for the Edison plug on the back on the Pedal Power 2... :oops:
If anyone has any thoughts or suggestions they would be appreciated.
David
Re: Attempting to use Pedal Power 2 Plus w/Vocalist Live 2 ??
The Vocalist Live 2 requires AC power. You will have to use the Courtesy Outlet on the back of the Pedal Power 2+. Alternatively, either of the high current outputs of the Pedal Power AC will power the Vocalist Live 2.
DRJM
Post by DRJM »
Yesterday I did purchase an AC pigtail with two plugs. I did run that off of the courtesy plug.
Specifically are you saying that outputs 5 or 6 or both combined should run the Vocalist?
I don't want to splice the HPRO power transformer but I am starting to wonder if its the actually power connector that comes from the power supply plugging into the Vocalist Lice. Those are about $60 to replace so I may just have to continue using the pigtail.
The Vocalist Live 2 cannot be powered from any of the front panel jacks on a Pedal Power 2+. It can, however, be powered using the supplied adapter connected to the Courtesy Outlet on the back of the Pedal Power 2+.
I'm not quite following you on the last part about the pigtail and splicing the supplied power supply. Does the supplied adapter power up the Vocalist when connected to a wall jack?
DRJM
Post by DRJM »
Yes it works just fine plugged into a wall.
I understand that my only option is to use the courtesy plug.
