TC-electronic Nova delay pedal
Louv
Post by Louv »
I have the Voodoo Lab Pedal Power and it appears that none of the connectors will accommodate my TC-electronic Nova delay pedal (ND-1 Nova Delay).
Is the Voodoo Lab Pedal Power unit compatible with my pedal?
Do I need a different cable? I see on the web site that there are a half dozen cables.
Does anyone get their TC-electronic Nova delay pedal to work with the Pedal Power supply?
Re: TC-electronic Nova delay pedal
A Pedal Power 2 or a Pedal Power 2+ can power the Nova Delay from Output 5 or 6 with the Dip switch set away from Normal (On) using one of the standard barrel connector cables that came with the Pedal Power.
Louv
Post by Louv »
The cables I was supplied with do not fit either. I look at the extra ones better when I get home.
Louv
Post by Louv »
All is good now. I wish I looked into this more when I first got my Nova delay pedal.
Thanks for the help.
