Can the PP2+ power Effectrode's Blackbird preamp?
They say it needs 1200mA 12VDC. Can I use the aux AC outlet to power it somehow? Looks like it comes with a wall wart, which won't fit in the cutout on my Pedaltrain.
Re: Can the PP2+ power Effectrode's Blackbird preamp?
This would have to be powered using the supplied power adapter. If you need the reach through a Pedatrain, then one of the grey 3 to 2 prong adapters usually does the trick to extend the outlet through the bars on the back of the pedalboard.
