Pedal Power Mondo Questions
Posted: Mon Apr 06, 2015 7:04 am
I'm looking to buy a Pedal Power Mondo and had some questions in regards to how it would handle my setup.
My pedalboard is as follows in no particular order:
Digitech Whammy 5
Pigtronix Mothership
Pigtronix Philosopher King
Moog Clusterflux
Moog MF-Drive
Moog MF-Boost
TC Electronics Polytune
Line 6 M5
Electro-Harmonix Superego
Molten Voltage Tempode
Molten Voltage CV-Sync
Molten Voltage Splitty
The eight pedals below the Clusterflux, I believe that I should be able to use the "1-8" power supplies without a problem. It is the other 4 pedals that I am curious about.
I believe that since the Whammy is 1300mA, that I will need to use the courtesy outlet, is this correct?
The Pigtronix Mothership is one of the newer models that uses a 18V, 300mA power supply. Could I combine the first two high current outputs for this? If so, do I need to change any dip switches or anything? Also, can you let me know specifically which cable that I would need to buy for this to make it work?
The Philosopher King is the exact same power supply as the Mothership, so I basically have the exact same questions for this one except that I'm assuming that I could combine the 3rd and 4th hight current outputs here.
The Clusterflux uses a 9V, 400mA power supply, so I assume that I can use the 5th high voltage supply for this. I seem to remember that the Moogerfooger pedals use a different type of cable though. Can you point me to where I could buy this as well?
Thanks SOOOOO much!!!
Digitech Whammy 5
Moog Clusterflux
Moog MF-Drive
Moog MF-Boost
Line 6 M5
